1990 Nissan Pulsar NX security
pine_pony
Posted: July 26, 2003 at 12:26 PM / IP Logged
I need the wires colours and locations to put an alarm in my car but everywhere i lokk on the net nobody has them. Someone help!!
tjdurham
Copper - Posts: 180
Posted: July 26, 2003 at 8:17 PM / IP Logged
i have info on a 91 try it just test to verify
12v white , ig bk/red, starter bk /wh, door pin /red white at pass pin, pk lite RED / blue, trunk lite red (at light  ) lock and unlock are the same wire lt green /black  negative to lock and interrupt to unlock wire may be in the kick panel but if i can remember its in drivers door
tj
draasch
Gold - Posts: 2,172
Posted: July 27, 2003 at 11:38 AM / IP Logged
Make:   Nissan
Model: Pulsar NX
Year:    1987-90
This Database Was Last Updated On:    6/9/03
Index #: 412
Alarm
Constant 12 volts BLACK/ RED IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ WHITE IGNITION SWITCH HARNESS
Starter BLACK / YELLOW IGNITION SWITCH HARNESS
Dome Light YELLOW/PURPLE (-) AT PIN SWITCH
Trunk Pin Switch RED / BLACK (-) AT LIGHT
Parking Lamp GREEN/ BLACK (+) AT LIGHT SWITCH
Power Lock ADD ACTUATOR POWER LOCKS MUST BE ADDED #204
Power Unlock ADD ACTUATOR POWER LOCKS MUST BE ADDED #204
#204- See Adding Actuator Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
