Fuel pump kill switch on 95 Integra
Jdm R
Member - Posts: 14
Posted: July 28, 2003 at 11:29 PM / IP Logged
would it look like this: just connect the 30 to the switch?
Fuel pump kill switch on 95 Integra -- posted image.
i wouldn't connect the "to ignition 12v" right?? like this:
i was thinkin' of using this type of switch for added security:
you guys can check this thread i started on Honda-Tech fo more back round info on wat i'm trying to do: http://www.honda-tech.com/zerothread?id=573277
any help is greatly apreciated, thanks...
1995 Integra LS 5 speed
-RSpec106@netscape.net
Jdm R
Member - Posts: 14
Posted: July 28, 2003 at 11:31 PM / IP Logged
My thread on H-tech
tv4free
Member - Posts: 20
Posted: July 28, 2003 at 11:50 PM / IP Logged
hey jdm... I am a honda man too.Im looking at your relays and I dont  think i would do it like that.. I would  first  ground one side of your switch and the other side take it to pin 85 on your relay.86-needs to be 12 volts(+)..then 30 will go to your fule pump. and 87-will go to the hot side of your fule pump(the wire you cut) I hope this is what you ment......good luck
Jdm R
Member - Posts: 14
Posted: July 28, 2003 at 11:57 PM / IP Logged
so i would use 1 relay right?
wat do u "86-needs to be 12 volts(+)" wat do i connect 86 to?
Jdm R
Member - Posts: 14
Posted: July 28, 2003 at 11:59 PM / IP Logged
what do u mean "86-needs to be 12 volts(+)" what do I connect 86 to?
thanks fo da help i'm new to all this relay stuff
tv4free
Member - Posts: 20
Posted: July 29, 2003 at 12:14 AM / IP Logged
you need to give it a 12 volt ign to activate the relay...iyou said you wanted to have the key on right?
Jdm R
Member - Posts: 14
Posted: July 29, 2003 at 6:24 AM / IP Logged
i just want to be able to kill the fuel pump when i leave the car sum where I want to be able to switch it off, that's all. Is it better to have the key in the ignition to switch off da fuel pump?
Where would i locate the 12 volt ign wire i need to tap into to??
Jdm R
Member - Posts: 14
Posted: July 29, 2003 at 11:20 AM / IP Logged
chech dis diagram from WOTTEG from Honda-Tech
this is tha link:
http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wMTM5NzYxNnM0MTNkZmQzMXk1NDE%3D
would this be all good?
tv4free
Member - Posts: 20
Posted: July 30, 2003 at 12:34 AM / IP Logged
Hey there again. I was just looking at this diagram and I would have  to say it would work just make sure that the switch you are going to use(if it is the one you showed me it should work i had one on mine like the for my nos set up and i never had any thing go wrong, but the way this pic looks it is setup for a hi current system and i  dont know how much curent is been used............my answer   is  YES it  will work. anything eles you would like to ask?
Jdm R
Member - Posts: 14
Posted: July 30, 2003 at 10:48 AM / IP Logged
where's a good place to mount the relays and the ground wires?
also where is the 12V ignition wire (white wire) is there 1 i can tap into near the fuel pump.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
