Autopage rf-310 installation
edmondsm
Posted: July 29, 2003 at 6:50 PM / IP Logged
I am having difficulty installing the rf-310 in my 2001 f150 I have the keyless entry and don't know where to hook into the door lock and the running lights.  if anyone has a diagram or just plain knows how to hook it up please let me know or I am gonna have to break down and pay for an install.
cool_greg
Copper - Posts: 125
Posted: July 29, 2003 at 8:39 PM / IP Logged
Try this, it's for 2000 f150, so chances are that the wiring colors are the same, but do verify it
12V Yellow Ignition Switch
Starter RED / Blue Ignition Switch
Ignition 1 Blue/Green Ignition Switch
Ignition 2 Gray / YELLOW Ignition Switch
HVAC 1 RED / Black Ignition Switch
HVAC 2 NA NA
Accessory BLACK/ Green Ignition Switch
VATS NA NA
Hot Side Brake NA At Brake Switch
Cold Side Brake RED / Green At Brake Switch
Tach WHITE/ Pink At Coil
Lock Pink / YELLOW Left Kick Panel
Lock Type 5 wire positive
Unlock Pink/Green Left Kick Panel
Unlock Type 5 wire positive
Trunk Release NA NA
Trunk Release Type NA
Head Lamp RED / Yellow At Switch
Head Lamp Type Positive
Park Lamp Brown At Switch
Park Lamp Type Positive
Door 1 BLACK/ Blue Left Kick Panel
Door 1 Type Positive
Door 2 NA NA
Door 2 Type NA
Door 3 NA NA
Door 3 Type NA
Trunk Pin NA NA
Trunk Pin Type NA
Horn Dark Blue Steering Column
Horn Type Negative
OEM Arm NA NA
OEM Arm Type NA
OEM Disarm Dark GREEN/ Purple Left Kick Panel
OEM Disarm Type Negative
Sense Pink/Orange RKE drivers side
Sense Type Positive
LF Window Up WHITE/ Black
LF Window Down ORANGE / White
RF Window Up WHITE/ Yellow
RF Window Down Tan/Blue
LR Window Up Gray/Orange
LR Window Down Yellow/Blue
RR Window Up Yellow/Black
RR Window Down RED / Blue
Window Location   At Drivers Window Switch
Windows Type Reverse Polarity, Positive, Normally Grounded
Notes Vehicle equipped with Transponder. For keyless entry upgrade to an alarm, Arm = Pink/Black (+), Disarm = RED / Orange(+), both located in drivers door or door jamb, Sense = same as above.
and here is the wiring diagram for 5 wire positive.
5 wire postive locks
Just a Guy, Wiring up those Vehicals
Gool_Greg
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
