`98 Grand Am remote start
fordfan
Copper - Posts: 67
Posted: July 30, 2003 at 8:05 PM / IP Logged
I`m having problems finding the resistance value on this car. I have Omega`s "The Disk" program and I followed the directions word for word and still nothing. How long will the meter show the ohm rating could my meter not be responding fast enough? Any help would be appreciated. Thanks!
draasch
Gold - Posts: 2,172
Posted: July 30, 2003 at 9:20 PM / IP Logged
is this the info that you have???
Remote Start
Tach Signal WHITE AT POWERTRAIN CONTROL MODULE * #233
Ignition #2 ORANGE IGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3 WHITE IGNITION SW. HARNESS (TRANSMISSION)
Accessory BROWN IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light L BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light L GREEN (+) AT SWITCH ON DR. SIDE OF TRANSAXLE
Rear Window Defrost L BLUE (+) AT REAR WINDOW DEFOGGER SWITCH
* Powertrain Control Module Is Located Behind Passenger Dash Above Passenger Kick Panel. #233 - See G.M. Passlock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
