1997 grand prix remote start add on help
robul
Posted: August 02, 2003 at 11:31 AM / IP Logged
Ok,
I am installing my add on remote start that works with the factory alarm.. everything is fine but I cant find the light blue wire that has the negative pulse triggered by the lock button on the FOB, I tapped into the one on the BCM and i am able to start the car by pulsing the door lock button in the car 3 times..
the way it works is it needs 3 negative pulses and the car will start.. so i need the wire that supplies a negative pulse when the lock button on the keyfob is pressed.. hell id even give up the panic button on the car if i could get a negative pulse out of it. anybody know where the panic wire is?.
even the trunk button but that is a positive pulse.. mabye i could switch it with a relay but then id have to track that wire down also..
any help appreciated..
and my diagram says btw... power lock located 16 pin connector in driver kick panel and its l blue but there is no 16 pin connector... <>NoImage = NoSigImage<>NoImage = NoImageRes
draasch
Gold - Posts: 2,172
Posted: August 02, 2003 at 2:12 PM / IP Logged
Power Lock L BLUE 16 PIN CONNECTOR IN DRIVER KICK #201
Power Unlock WHITE PANEL OR AT BODY CONTROL MODULE ***
*** Body Control Module (BCM) Located Behind Driver Dash To Left Of Steering Column. #201- See Negative Pulse Door Lock Diagram..
use a meter to help you find the wire.find the lt. blue, probe it and press the lock button on trans. you should be avble to find it.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
robul
Posted: August 02, 2003 at 2:39 PM / IP Logged
yeah i found all the wires.. i found the negative pulse wire.. and hooked it up... and if i hit the lock button inside the car 3 times vrooom car starts right up.. but on the FOB probing that same wire I do not get the negative pulse.. i can only get the pulse when i hit the lock button in the car..
any ideas?
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
