heated seats on with remote start
brianh
Silver - Posts: 518
Posted: August 17, 2003 at 7:24 PM / IP Logged
Has anyone done this particular install on a 2003 Suburban? If so can you tell me how you made it work. I know that this vehicle has 2 heat settings. If anyone has any info I would really appreciate it. Thanks in advance.
Brian
owner/installer
Sight & Sound Car Stereo
"all electronic equipment runs off of smoke, once you let it out, it stops working"
brivalen
Member - Posts: 31
Posted: August 17, 2003 at 7:37 PM / IP Logged
You will most likely need a factory service manual. On my 01 Grand Cherokee there is one wire that sends a OHM signal to the BCM. 1000 ohms for high and 300 for low, all i had to do was use a positive while remote starting - but i decided not to do that because who wants heated seats in the summer. Its easier to just remember to leave them turned on in the winter or install a simple inline switch.
brian
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
