2003 Chevy Silverado LS door triggers
Branman
Posted: August 18, 2003 at 8:48 PM / IP Logged
I need to know what are the driver and passenger door trigger wires on a 2003 Chevy Silverado LS because i cant get the alarm/starter combo to work with the domelight so im going for the door trigger thanks.
JamesRH
Copper - Posts: 102
Posted: August 19, 2003 at 12:43 AM / IP Logged
If im remembering correctly...the warning light for "door ajar" is the easiest place in those trucks...might be thinking of another make though :(...its been a while since i seen inside a silverado
anonymous
Member - Posts: 24
Posted: August 19, 2003 at 10:27 AM / IP Logged
At the BCM right under the steering column. If I remember correctly the driver's door should be orange, and the passenger door tan. They should be in the plug farthest to the right. You can also get them at the plugs at either end of the dash where the wiring comes in from the door.
Happy metering
Anonymous
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
