need help with new alarm on truck
bear80
Member - Posts: 21
Posted: September 01, 2003 at 7:43 PM / IP Logged
 i got me a 2003 silverado i am going to try to install a new car alarm in it my truck has no elec. lock 's in it  the alarm  has a lock&unlock on it  if it has built in relay 's for door lock   i got some door  lock actuators motors for it  will i need more for this to lock&unlock my doors and if some one can help me with the wiring  on this truck  the alarm is a performance teknique alarm with start motor is it hard to install or what need help with new  alarm on truck -- posted image.
draasch
Gold - Posts: 2,172
Posted: September 01, 2003 at 7:57 PM / IP Logged
what type of output do you have on the alarm?????
look at this info:door locks under car security to the left of this screen
look towards the bottom of the list:
Added Actuator(s)
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
samdub
Member - Posts: 41
Posted: September 01, 2003 at 10:33 PM / IP Logged
if your alarm has built in relays you should only need actuators, as far as remote start you need too know if the truck has a passlock system if so you will need a bypass there are two different passlocks gm still uses 2 or 3
samdub
Member - Posts: 41
Posted: September 01, 2003 at 10:41 PM / IP Logged
according too the info i have it has passlock 2 if any at all, you will need a gm passlock 2 bypass this install is difficult
bear80
Member - Posts: 21
Posted: September 02, 2003 at 5:30 PM / IP Logged
thank's for all you guy's help
