help,power window not working!
jac2
Member - Posts: 36
Posted: September 04, 2003 at 6:46 PM / IP Logged
i installed hornet 554t in my 2000 honda accord v6 coupe (i didnt connected the door lock/unlock wire because instruction said i need a relay to connect with it,and it doesnt came with the door lock/unlock relay!!!)since then my  right side powerlock and power window didnt work,so i took alarm off the car.and somehow i fixed the lock,i just touched lock/unlock wires with my tester and it works fine after that but right side power window still not working.it sounds tick,tick when i push the switch up and down.seems like sending a power but not even moving a bit .is there any possible reason that cause this kinda problem??
jac2
Member - Posts: 36
Posted: September 04, 2003 at 9:58 PM / IP Logged
i have to close the window before rain.anybody??! plz help!!
JWorm
Platinum - Posts: 2,208
Posted: September 04, 2003 at 9:59 PM / IP Logged
Check all the fuses in the car. You sure nothing came unplugged?
You don't need any additional relays to do locks on that car. They are negative trigger/
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
