98 ford van power windows
rjday
Posted: September 12, 2003 at 4:47 PM / IP Logged
picked up a used  van and having trouble figuring the wiring for the power window wiring type. when i checked the power window switch it checked out like a 5 wire alternating + 12 v dc. but everything i've found on this system says it should be a reverse polarity or maybe negative trigger. i have a manual on order but would like to get started on this asap. any help would be appreciated.
jerry e day
rjday@peoplepc.com
milan michigan
draasch
Gold - Posts: 2,172
Posted: September 12, 2003 at 8:41 PM / IP Logged
are they factory windows?????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
rjday
Posted: September 13, 2003 at 7:17 AM / IP Logged
1998 ford conversion van: sorry error on my part. been looking at to many wiring diagrams lately. i'm installing remote power locks using cool start RS900 series V, remote start is working ok but the wiring for the remote locks slowing me down. wires checked out as follows. 1.) 1 -black w/white stripe has12   v dc always hot.   2.) 1-red has continuity at rest, and 12 v on lock.  3.) 1-brown has continuity at rest, and 12 v on unlock.  4 & 5.) 2-black wires have continuity to ground and open when switch in engaged (lock or unlock). this is on the front door passenger's side. is this a standard reverse polarity wiring system??? will be trying remote windows latter.  david thanks for the reply, sorry about the confusion.
jerry e day
rjday@peoplepc.com
milan michigan
draasch
Gold - Posts: 2,172
Posted: September 14, 2003 at 11:09 AM / IP Logged
Make:   Ford
Model: Econoline
Year:    1998
This Database Was Last Updated On:    6/9/03
Index #: 5090
Alarm
Constant 12 volts YELLOW (2) IGNITION SWITCH HARNESS
Ignition 12 volts RED / L GREEN IGNITION SWITCH HARNESS
Starter WHITE/ PINK IGNITION SWITCH HARNESS
Dome Light BLACK/ L BLUE (+) AT ANY PIN SWITCH
Trunk Pin Switch SAME CIRCUIT AS DOME LIGHT
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH *
Power Lock RED 8 PIN GRAY CONNECTOR #203
Power Unlock BROWN IN DRIVER KICK PANEL ** #202
* BROWN (+) Wire For Parking Lights Is Also Located In A 6 Pin Connector In The Driver Kick Panel. ** Without OEM Keyless Entry Door Locks MUST BE TESTED FROM PASSENGER SWITCH!! Without OEM Keyless See Note #203. With OEM Keyless See Note #202 #203- See Reversal Rest At Ground Door Lock Diagram. #202- See Positive Pulse Door Lock Diagram.
Window Up D\ WHITE/ BLACK P\ WHITE/ YELLOW @ MAIN #211
Window Down R/ YELLOW S/ TAN/L BLUE SWITCH
Ign Key Warn BLACK/ PINK (-) IGNITION SWITCH HARNESS
Trunk Release N/A
OEM Horn D BLUE (-) STEERING COLUMN HARNESS
Headlights RED / YELLOW (+) AT HEADLIGHT SWITCH
OEM Alarm Arm N/A NO OEM ALARM PRESENT
OEM Alarm Disarm N/A IN SCHEMATICS
#211- See Reversal Rest At Ground Power Window Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
