1992 Same as 1994 LeBaron ?
Atmelflash
Posted: September 20, 2003 at 11:51 AM / IP Logged
In the diagram section there is a pin out for the 1994 LeBaron listed there. Does anyone know if the 1992 LeBaron is wired the same way(color wise)?
The CARBINE AL775 Alarm I have has a 2 wire ( RED / black withplug) on it for the locks. With the 1994 your diagram lists the car as having a 5 wire system. Is this true for the 1992 also and would it require the use of relays, or will the 2 wires with plug off the alarm just hook up to this?
And IF I do need these relays how/where do I get them and place them in the car??
Thanks guys!
Platinum - Posts: 12,488
Posted: September 21, 2003 at 9:20 AM / IP Logged
The wiring is different between the two models years. The door lock systems for both years are the same and you will require 2 relays to bypass the locking system. You can find the wires at the DKP.
