Auto Start
Redrabit69
Member - Posts: 16
Posted: October 07, 2003 at 7:40 PM / IP Logged
I`ve designed an auto start which I`ve yet to make, I`ve just got one question.
My ignition has ACC, ON, and START (and off obviously)
With the key at ACC, the ACC wire goes to GND
at ON, the ACC and ON go to GND
at START, the START and ON wire go to GND (but not ACC)
Is there any reason why ACC can`t also be connected when the key is in the START position?
Hope thats clear enough, any help would be great, cheers!
JWorm
Platinum - Posts: 2,208
Posted: October 07, 2003 at 8:26 PM / IP Logged
Accessory shuts off during crank to provide more battery power to the starter motor. During cold weather when the battery is weakened the starter neads all the juice it can get. Powering the heater, radio, etc. at the same time as the starter motor requires a lot of current.
JWorm
Posted: October 07, 2003 at 8:32 PM / IP Logged
Why design your own remote start...just grab 10 relays and make the following Auto Start -- posted image.
http://home.comcast.net/~jschaefer4577/remotestarter.jpg
Redrabit69
Member - Posts: 16
Posted: October 07, 2003 at 8:44 PM / IP Logged
Because mine only uses 6 relays ;) (wether it works remains to be seen!) That one has 4 switch positions tho, my car only has 3 so that might be why.
I just remembered I made a starter button a while ago (was cool until I realised I still needed the key to disengage the steering lock, defeated the purpose of it really...) and that had the ACC connected with no problems...
So there is no harm in having it connected other than it won`t always work? (and obviously drain the battery if I keep trying it :) )
Guess I`ll try to do it proporly tho :)
Cheers!
Redrabit69
Member - Posts: 16
Posted: October 14, 2003 at 10:26 PM / IP Logged
Update: Made mine with 6 relays (with ACC attached, haven`t had a problem starting yet, but it is summer) and its going fine, haven`t used the key to start it in over a week (too much fun Auto Start -- posted image.
JWorm
Posted: October 14, 2003 at 10:48 PM / IP Logged
Curious, but what triggers the system? Anyway you could give a relay diagram? Glad its working for you.
Redrabit69
Member - Posts: 16
Posted: October 15, 2003 at 1:27 AM / IP Logged
Its connected to the 2-channel output on my alarm ie: when I push button 2+3 on my remote it sends a (-) pulse for about 2 seconds. I`ve posted a diagram in another message
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
