2001 mustang wiring diagram needed please
alexdesignz
Posted: July 16, 2002 at 1:56 PM / IP Logged
does anyone have this info
dan768
Copper - Posts: 49
Posted: July 16, 2002 at 7:00 PM / IP Logged
Yep,
Year(s): 99-02
Make(s): Ford
Model(s): Mustang
As Of: 03/04/02
12 Volt (+)
14ga. Yellow at ignition harness or 14ga. YELLOW /GREEN at R.K.E. above driver’s kick panel (connector faces forward)
Ignition 1
12ga. RED / Green at ignition harness or 18ga. WHITE/ Green at R.K.E. in White connector
Ignition 2
12ga. Gray / YELLOW at ignition harness
Ignition 3
12ga. RED / Black at ignition harness
Accessory 1
12ga. Gray / YELLOW at same or 14ga. Blue/Black at R.K.E. (connector faces firewall)
Accessory 2
12ga. BLACK/ Green at ignition harness
Starter
14ga. WHITE/ Pink or Blue/Red at ignition harness
Horn
18ga. YELLOW /GREEN (-) at R.K.E. (connectors facing down)
Tachometer
18ga. Lt. GREEN / WHITE at P.C.M. in passenger’s kick panel
Lights (+)
18ga. Brown at R.K.E.
Lights (-)
Brake Lights
18ga. RED / Green (+) at brake pedal switch
Door 1
18ga. Yellow/Black (-) (driver door) at R.K.E. (isolate to prevent false triggers) (for KS2040 installs)
Door 2
18ga. Gray/Red (-) (passenger door) at same (isolate to prevent false trigger) (for KS2040 installs)
Door 3
Door 4
Interior Lights
18ga. BLACK/ White (+) at same (for KS4040 installs)
Trunk/Hatch
18ga. BROWN / White (-) at same (isolate from keyless entry module with diode, cathode faces rear of vehicle, tag rear half of wire)
Hood Pin
Trunk Release
18ga. Pink/Green (-) at same (motor wire is Violet / YELLOW in driver’s kick panel)
Lock (switch)
18ga. Lt. Green (+) at same
Unlock (switch)
18ga. Violet (+) at same
Driver Unlock
Arm (key)
Disarm (key)
Arm Input
16ga. Pink/Black (M) or RED / White (M) at R.K.E.
Disarm Input 1
16ga. RED / Orange (M) at same
Disarm Input 2
16ga. Pink/Orange (M) at same
LF Window Up
LR Window Up:
LF Window Dn
LR Window Dn:
RF Window Up
RR Window Up:
RF Window Dn
RR Window Dn:
Additional Info
It may be necessary to also isolate trunk 12v (+) wire to prevent false triggers. At the R.K.E. find the 18ga. GREEN/ Red (+) wire and splice a diode in
line with the cathode facing the rear of the vehicle.
dan
Remember (there are no hard cars,some just take longer to install on then others)
alexdesignz
Posted: July 17, 2002 at 9:04 AM / IP Logged
thanks alot
