door trigger problem.. please help
l8zer
Member - Posts: 11
Posted: July 16, 2002 at 6:20 PM / IP Logged
Vehicule is a VW Golf 2000, w/o power windows.
I have the alarm in place and functioning, but not like it should be.
After I arm the alarm it always reports me that a door is open even though both of them are closed.  My door contact switchs are working fine also..
I narrowed down the problem to this situation:
door is open, volt meter (-) connected to the BROWN / yellow wire for the driver door I get a signal, which is fine.
door is closed, volt meter (-) connected to the same wire, I get no signal, which is also fine.
Now, here's the tricky part... I arm the factory alarm using my key fob and the the signal comes back... saying the door is open.. the dome light is off in the door.
By the way the unit I'm installing is a Hornet 700T, factory keyless upgrade.
Is there another wire I'm supposed to use?
My 2 doors are diode isolated so I know that is not causing any problem.
dan768
Copper - Posts: 49
Posted: July 16, 2002 at 7:11 PM / IP Logged
Hey bub, these are the colors I use
Door 1
18ga. BROWN / Yellow (-) (driver door) at Gray connector (power window models are multiplexed and the door triggers exist only in each door as
Door 2
20ga. BROWN / Blue (-) (passenger door) at same BROWN / White, so use interior light instead for door trigger even with the delay unless
Door 3
20ga. BROWN / White (-) (rear doors) at same otherwise requested)
Door 4
Interior Lights
18ga. Blue/White (-) (may appear as Blue/Gray) at same (1 of 2 this color)
Trunk/Hatch
20ga. BROWN / Black (-) at same
Hood Pin
18ga. BROWN / Red (-) at Brown connector
dan
Remember (there are no hard cars,some just take longer to install on then others)
l8zer
Member - Posts: 11
Posted: July 17, 2002 at 5:50 AM / IP Logged
I'll try to get the interior light for the contact switch instead...
I also need to have the trunk bypass feature working so I can open my rear lid without having the alarm triggered.  Right now I have a relay connect to the BROWN / black release switch from the lid.  I need a relay here cause the alarm is expecting a (+) and this wire is (-).  It seem to bypass it, but when I close tthe lid, it triggers the alarm right away... its actually suposed to delay 3 seconds then start monitoring again.
Thanks for your help.
Thursday, January 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
