1992 toyota paseo remote starter
luism0210
Posted: October 13, 2003 at 11:39 AM / IP Logged
I need a wiring diagram for 92 paseo
luism
daniel2002p
Silver - Posts: 524
Posted: October 13, 2003 at 6:46 PM / IP Logged
12v - WHITE/ green or WHITE/ red               ignition harness                   +
starter - BLACK/ white     ignition harness       +
ignition - BLACK / YELLOW      ignition harness       +
second ignition - nlack/red      ignition harness       +
accessory - blue/red     ignition harness         +
parking lights - green     drivers kick       +
door trigger - BLACK/ white      2-pin plug at fuse block         -
factory alarm arm - WHITE/ green                driver kick   -
                         disarm - WHITE/ blue         driver kick     -
tach - black or BLACK/ blue
brake wire - GREEN / WHITE      brake pedal swith      +
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
