LED's
fireman1321
Member - Posts: 20
Posted: October 13, 2003 at 6:18 PM / IP Logged
I wired 2 green 2v leds to my dei alarm in a series... one of the leds dont work... what do y-ou think might be the problem???
Future Fire Man
auex
Platinum - Posts: 5,041
Posted: October 13, 2003 at 6:43 PM / IP Logged
Well, the wire going between the wires could be grounded out somewhere. It probably is unlikely that the led is bad, if it where then the led's probably wouldn't work at all.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
misterjimbo
Silver - Posts: 535
Posted: October 13, 2003 at 9:43 PM / IP Logged
i wire my LED's in parallel configuration with no prob, on audiovox/pursuit/prestige units
Ocelaris
Posted: October 14, 2003 at 6:47 AM / IP Logged
The DEI alarm is probably putting out only 2 volts, meaning it will only have power to run 1 LED in series. You need to run them in parallel like misterjimbo said above. or if you haven't tested them individually yet, I would reccomend that also...
HamiltonAudio
Silver - Posts: 278
Posted: October 17, 2003 at 7:38 AM / IP Logged
if you're only wanting to add LED's to add to the "flashing light" theory inside the car, why not get 12V self-flashing LED's?  Use the starter disable output to trigger a relay, and turn on 10,000 of these if you want.  I've been using em for years with great success.
b
auex
Posted: October 17, 2003 at 5:24 PM / IP Logged
Ocelaris: Even according to dei, you are supposed to wire led's in series and you can have upto five. If you wire them parrallel then they will try to draw to much current and burn the led output out. Also I have 5 led's wired in my car and they are in series and have worked fine for the last 3 and a half years.
misterjimbo
Silver - Posts: 535
Posted: October 17, 2003 at 7:46 PM / IP Logged
auex... very good. sometimes we forget basic elec. laws. you are correct.
fireman1321
Member - Posts: 20
Posted: October 20, 2003 at 9:31 PM / IP Logged
How can I wire in led's through a relay??? I want to use the pos and neg of the output of the led and out them to 85 and 86 then have constant go to 30 and series 6 LED's from 87.... anyone think or might know how I can do that???
Future Fire Man
auex
Posted: October 20, 2003 at 10:14 PM / IP Logged
You cannot use a relay for this application. If I remember, you have a dei alarm and they only put out two volts to the led and it won't energize the coil in the relay. Not saying it can't be done just not with a relay.
fireman1321
Member - Posts: 20
Posted: October 21, 2003 at 7:03 PM / IP Logged
How can I get my LED's to work??? just do it in series?!?! it doesnt work...
Future Fire Man
Sunday, December 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
