85 Celica Keyless / Remote Start?
manofsteel
Member - Posts: 6
Posted: October 24, 2003 at 9:40 AM / IP Logged
Installed a remote start/keyless entry in 85 Celica. I have a Haynes and Clymer repair guide for my car and it has some electrical diagrams but I'm still lost.
My Haynes has 9 pages of schematics that are hard to read. It has a box that says "Ignition S/W" and has ACC, IG, ST and AM wires coming out. I would assume these to be ACCessory, IGnition, STart, and I have no idea what the AM is. For ACC it shows LB as the color (Light blue with black?), IG is BY (Black w/ yellow?) and ST is BW (Black with white?). My Clymer book says the ignition switch CONNECTOR has different terminal (wire colors).... like Light Blue with Red for ACC, Black w/ yellow for IG, etc.
Anyone have a diagram for my car? Or someone who can read schematics I can scan the schematics so you can read it or teach me how to read it? Thanks in advance! It's a keyless entry with remote start unit.
daniel2002p
Silver - Posts: 524
Posted: October 24, 2003 at 11:43 AM / IP Logged
starter                BLACK/ white           +
ignitoin                BLACK / YELLOW               +
accesory                  BLACK/ orange           +
second                       accesory blue/red            +
tach                             WHITE/ blue
brake                      GREEN / WHITE              +
power lock              blue/black      negative trigger      driver kick
power unlock             blue             negative trigger            drivers kick
park lights            lt. green           negative trigger          column
Please double check these wires with a DMM.  I am not 100% sure of these.  Hope this helps.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
