99 Honda Accord EX
Honda99
Member - Posts: 21
Posted: October 26, 2003 at 10:07 AM / IP Logged
hi ...i have a honda accord 99 ex and i have a viper alarm/remote starter system. i need to instal to my car so anyone can help me with it....i know i have to get a bypass module. and i don't know do i need other module for bypass factory alarm. thanks
Platinum - Posts: 12,488
Posted: October 26, 2003 at 7:05 PM / IP Logged
1999 Accord arms and disarms with the door locks on the EX models.  The LX models arm only with the factory transmitter. There is a module that will bypass the OEM security, do the door locks and pop the trunk as well.
Havock
Member - Posts: 10
Posted: October 26, 2003 at 10:20 PM / IP Logged
The only thing you will need is the bypass module.  but you must give up one of you FACTORY KEYS in order for this to work if you use the key module one... I actually installed a viper alarm/starter on my girls' 4dr honda 98.. Now she has a 02 special edition so I put the 2way omega on that one... If you need the color codes let me know...
p.e.a.c.e.
Honda99
Member - Posts: 21
Posted: October 27, 2003 at 8:10 AM / IP Logged
hi....i have a viper 791xv and my friend told me need a bypass module(PKH2 or 555H) with this i don't need to lost my factory keys...but i wondering is do i need another module to bypas the factory alarm system.yes i do need a color codes for starter and alarm. plsthanks.
Posted: October 27, 2003 at 8:43 AM / IP Logged
Either one of the bypasses will work and if you wanted to you could use the HODL alarm bypass , door lock interface with trunk release ( if applicable ) to bypass the OEM alarm when remote starting. The Honda Accord disarms with unlock and arms with lock. Email me for modules
AutoObsessions
Member - Posts: 26
Posted: October 28, 2003 at 10:02 PM / IP Logged
12 volts - White
Starter - BLACK/ White
Ignition - BLACK / YELLOW
Ignition 2 - Yellow
Accessory - WHITE/ Black
Lock - BLACK/ blue which u will have to get at the factory security module. Worse comes to worse go in the door for them if u cant find it.
Unlock - Orange
Parking lights - RED / Black coming with the main ignition wires or you can plug into the open fuse box slot.
Door trigger - BLACK/ white passenger side fuse box
Trunk pin - orange in drivers kick panel
Factory alarm disarm with no unlock - Blue at the drivers power window switch. If you do not use this wire the security will also disarm with the unlock wire but make sure you hook it up so that the lock wore will get a neg pulse after the car starts to lock the doors again.
AutoObsessions
Member - Posts: 26
Posted: October 28, 2003 at 10:06 PM / IP Logged
Tachometer - Blue which u can get at the distribution block. Or on 4 cylinder engines behind the battery and on the 6 cyliner on a bracket attached to the driver side strut tower.
Brake wire - WHITE/ black at the brake pedal switch
Horn trigger - light GREEN/ blue at the steering column
I have had luck with either bypass but use the key bypass most of the time. Never had a problem with it so why try different things. Good luck!!
