Directions for new remote
ridethewind
Posted: October 30, 2003 at 11:59 AM / IP Logged
I have a 125HF remote starter installed in my Focus. While vacationing, the 471T remote that I had disappeared. After reading on DEI's site and many more, that the 473T will work on all HF models, I purchased one. Now I would like to program the module to work with the 473T remote. Could anyone help me out to get this remote working?
Ridethewind
johnnyd34
Member - Posts: 33
Posted: October 30, 2003 at 12:52 PM / IP Logged
If you have a valet/programming switch installed. Try this link. page 16 on the manual. This may work on your model as well.
ridethewind
Posted: October 30, 2003 at 1:10 PM / IP Logged
Thanks, but I can't see the link. I do have a switch for accessing the hood. The blue colored connector on the module has two pins. Do I hook a switch between the two pins?
ridethewind
Posted: October 31, 2003 at 7:47 AM / IP Logged
Yes, the valet switch is installed and hidden on the left side of the interior. I've looked for info about the 125hf but still have not come up with what I would like. Anyone know of a site with the directions?
ridethewind
Posted: October 31, 2003 at 5:48 PM / IP Logged
Okay, I got the remote programmed but the 473T's range is about 3 feet. What could be the problem here?
ridethewind
Posted: November 12, 2003 at 10:43 AM / IP Logged
Well, I had better finish this post. The 473T was returned with no problem at FutureShop. Picked up a 471T and all worked out well. Range is good. No problems now.
ridethewind
