2003 Hyundai Sonata Alarm/Remote Start/Stereo Wiring
yvonrichard
Posted: November 02, 2003 at 4:09 PM / IP Logged
please i nedd wiring info to install a remote starter on a 2003 sonata with a transponder and a factory alarm ... thanks
Javelin3o4
Copper - Posts: 239
Posted: November 02, 2003 at 10:00 PM / IP Logged
This is the wiring for the 2002 maybe the same but make sure to check all connections first...
|              12V|red    (x2)         |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|orange              |+  |ignition harness            |
|        ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|lt. blue            |-  |16P plug, pin 11, rear of FB|
|     POWER UNLOCK|white               |-  |16P plug, pin 10, rear of FB|
|       LOCK MOTOR|gray                |   |16P plug, pin 12, rear of FB|
|     UNLOCK MOTOR|tan                 |   |16P plug, pin 6, rear of FB |
|    DISARM DEFEAT|no progressive unlck|   |                            |
| PARKING LIGHTS +|purple              |   |16P plug, pin 15, rear of FB|
| PARKING LIGHTS -|lt. blue            |   |light switch,steering column|
|       HEADLIGHTS|white               |-  |light switch,steering column|
|     DOOR TRIGGER|yellow              |-  |12P plug, pin 9, front of FB|
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|GREEN/ black         |-  |20 pin plug, pin 12 in DKP  |
|         HOOD PIN|lt. blue            |-  |12 pin plug, pin 2, ETACM *1|
|TRNK/HTCH RELEASE|green *2            |-  |12 pin plug, pin 5, ETACM *1|
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |-  |                            |
| DISARM NO UNLOCK|RED / blu or lt grn *6|+  |ignition harness            |
|       TACHOMETER|white               |   |instrument cluster or ECM *3|
|      SPEED SENSE|brown               |   |data link connector *4      |
|       BRAKE WIRE|lt. blue            |+  |brake pedal switch          |
|     HORN TRIGGER|yellow              |-  |steering column             |
|           WIPERS|green (L), purple(H)|-  |steering column             |
|  LF WINDOW UP/DN|blue - brown        |A  |driver window switch        |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |driver door harness         |
|  LR WINDOW UP/DN|green - purple      |A  |16 pin plug in DKP          |
|  RR WINDOW UP/DN|lt. green - purple  |A  |16 pin plug in DKP          |
| SUN RF OPN/CLOSE|yellow - yel/red    |A  |sunroof relay *5            |
|        RADIO 12V|orange              |+  |radio                       |
|     RADIO GROUND|BLACK/ orange        |-  |radio                       |
|     RADIO SWITCH|yellow              |+  |radio                       |
| RADIO ILLUMINATE|BROWN / white         |+  |radio                       |
|    POWER ANTENNA|gray                |+  |radio                       |
|       LF SPEAKER|tan - black         |   |radio                       |
|       RF SPEAKER|blue - red          |   |radio                       |
|       LR SPEAKER|white - brown       |   |radio                       |
|       RR SPEAKER|orange - green      |   |radio                       |
Notes:
*1 The ETACM (Electronic Time & Alarm Control Module) is attached to the fusebox below the fuses.  *2 Can also use blue (+) solenoid wire in the 16 pin plug, pin 7 in the driver kick panel. The fuel filler release is green (+) in the 20 pin plug, pin 15 in the driver kick panel.  *3 The ECM (Engine Control Module) is to the right of the accelerator pedal. On the 4 cyl models with A/T the tach wire is in the 26 pin plug, pin 3. 4 cyl models with M/T it is in the 12 pin plug, pin 8. 6 cyl models it is in the 40 pin plug, pin 17.   *4 The data link connector is under the steering column.  *5 Remove the front map light assembly and the relay is visible in the right side of the opening.  *6 This is the key sense wire for the ignition switch. Triggering this wire at the same time as both ignition wires will disarm the factory alarm without unlocking the doors.
Monday, November 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
