2004 dodge ram1500 4 door truck.
mobiletoys2002
Gold - Posts: 1,050
Posted: November 09, 2003 at 8:05 PM / IP Logged
has anyone susecfully remote started this vehicle,if so can you give me wire color info on all wires including alarm info. I tried to do this car today and had a lot of problems first of all the ignition wire i cannot find one i found a small guage pink/white that tests like an ignition but when connected to remote starte rit does nothing but turn on the mileage guage.I found a thick wire taht tests 12 volts at ignition and drops out when cranking (all the info i have says it is the ignition wire, but i know taht this cant be if it drops out when cranking")someone help me im lost.
mobiletoys2002
Gold - Posts: 1,050
Posted: November 09, 2003 at 9:16 PM / IP Logged
Does anyone have (correct info)on this vehicle? I have 4 different programs telling me 4 different things. I have had problems with this vehicle like i have not found the ignition wire(well i have found one small wire that tests sorta like an ignition) this wire tests 12 volts one click before ignition and this wire tests 12 volts when in ignition and 12 volts wehen in start but this wire does not start the vehicle if i cut this wire the car still starts,the wire color is pink / YELLOW small guage. I have not found door lock wires that match what a bunch of programs tell me. I need info on alarm,remote satrt wiring please any info is apreciated asap please,thanks.
JWorm
Platinum - Posts: 2,208
Posted: November 09, 2003 at 11:45 PM / IP Logged
Check out my post at sounddomain I made on the 04 Ram
There are multiple wires with the same color, so I tried to describe the location in the plug.
http://forum.sounddomain.com/forum/ultimatebb.cgi?ubb=get_topic;f=9;t=002525
