Alarm draining battery
Ann Scotney
Posted: November 15, 2003 at 5:03 AM / IP Logged
I recently had a Clifford Concept 50 removed from my vehicle, Audi A4, as it drained my battery when the car was left unused.  It developed faults with the immobiliser and towards the end had to be run constantly in Valet mode with the sound switched off - not much use in having an alarm.
In its place I now have had a Sigma M30 (at considerable expense!).  My car has been left securely in a garage for 4 days with the alarm switched on.  All doors and windows were secured and there have been no false alarms, on returning the battery is flat.  Am I being conned by the installers as this seems to be the same fault as the Clifford alarm?  Please could anyone help - is there a simple installation problem?
Thanks in anticipation.
padawan
Copper - Posts: 215
Posted: November 15, 2003 at 8:00 AM / IP Logged
Most likely not an alarm problem, the only thing "on" is your LED which draws like .002 amps of current...That would never drain your battery...Check the vehicle for other things being left on, or even a faulty battery, Take somewhere and have it checked for dead cells etc...
auex
Platinum - Posts: 5,041
Posted: November 15, 2003 at 8:17 AM / IP Logged
Have the shop recheck there connections and see if anything they did would cause the computer to stay on instead of shutting down.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
HamiltonAudio
Silver - Posts: 278
Posted: November 15, 2003 at 7:03 PM / IP Logged
sure sounds like a problem with the vehicle to me!!  have them brain of the alarm disconnected from the car, and do some diagnostics.  First, is the battery actually OK, or is it dying anyway?  Also, have a technician with a clamp meter read what kind of draw is at the main battery cable connection when the car is off.....
we had a similar complaint a few weeks ago in a customers truck who had a snowplow hung on the front...he blamed the freshly installed remote starter on the battery always dying.  A simple set of tests revealed that one of the plow control solenoids was causing considering voltage leak, killing the battery.  Simply disconnecting this solenoid and replacing the battery, he went a week with no problems (and the remote starter working!!) and he was convinced...replaced the solenoid and we haven't seen him since  Alarm draining battery -- posted image.
many folk are quick to blame a starter/alarm for killing batteries...while it is technically possible for something to go wrong and cause a dead batt, its highly unlikely and I'd be suspecting something else in the car....
b
jrilla
Gold - Posts: 1,498
Posted: November 15, 2003 at 11:43 PM / IP Logged
Actuall y it could be the alarm if the installer screwed something up the first time, and then never fixed it when putting in the second one, since all the connections were made.
I am not disagreeing with any previous posts, I just thought that if thealarm was causing the drain, it really wouldn't be the unit itself, but more likely the installation at fault.
J Rilla
Owner/Installer
Ann Scotney
Posted: November 16, 2003 at 6:45 AM / IP Logged
Thanks for everyones help with this.  Seems it is an electrical problem unrelated to the alarm and the voltage drain is elsewhere.  Thanks for giving me some ammunition for the alarm installers - seems I have wasted a lot of money on the new alarm!!!
I'm going to get the car checked over for battery or any other sources of voltage drain.
Thanks again, much appreciated.
lspker
Silver - Posts: 503
Posted: November 23, 2003 at 9:08 PM / IP Logged
Check how the starter kill relay is hooked up, if wired incorrectly, it will draw current and kill battery.
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
