'95 Camry tach wire
siuto
Member - Posts: 10
Posted: November 24, 2003 at 12:18 AM / IP Logged
I know the color of the tach wire is black which is at the coil in my 95' camry.
but where is the coil located at????
or any other way to hook up the tach wire???
Justaguy
Copper - Posts: 112
Posted: November 24, 2003 at 12:50 AM / IP Logged
Just go to one of the odd colored injector wires.
profuse007
Gold - Posts: 2,015
Posted: November 24, 2003 at 1:04 AM / IP Logged
that model camry have two diff diagnostic port in the engine compartment and under the dash to the left. test the black wire, i came across with this some where.....dont know if it works
good luck
Houston,TX
siuto
Member - Posts: 10
Posted: November 24, 2003 at 1:12 AM / IP Logged
Thanks very much, there's lot of help, you guys~~~
sroth140
Silver - Posts: 513
Posted: November 24, 2003 at 2:22 AM / IP Logged
any time you possibly can, look at a few of the injectors, find a common wire, say they all have a black one.  then the others may be black and a red, black and a yellow, black and a blue, black and a orange.  use any of the non black ones.
HamiltonAudio
Silver - Posts: 278
Posted: November 24, 2003 at 9:19 AM / IP Logged
sometimes coil tach is either too high or too low. and sometimes injectors are the same...need to test to see which one works best for your unit (and after that experience will dictate)
b
profuse007
Gold - Posts: 2,015
Posted: November 24, 2003 at 12:05 PM / IP Logged
FYI, inline 4 camry injectors really hard to get ur hands on (more like impossible). the engine tilted and throttle body right ontop of it.
v6 is right under the V-cover.
Houston,TX
siuto
Member - Posts: 10
Posted: November 24, 2003 at 1:50 PM / IP Logged
I found the black wire which is coming out from the igniter under the hood....
is that the tach wire???
mxxmikexx
Silver - Posts: 796
Posted: November 24, 2003 at 7:55 PM / IP Logged
you can grab a BLACK/ orange under the glove box. alot quicker than running a wire into the engine bay.
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
