Nissan Gt Skyline info
autosound
Copper - Posts: 58
Posted: November 26, 2003 at 10:22 AM / IP Logged
Has anyone got any wiring info on the Nissan Gt Skyline...
the12volt
Administrator - Posts: 3,957
Posted: November 26, 2003 at 11:30 AM / IP Logged
Here's what I have for a 2001:
|       ITEM      |     WIRE COLOR    |POL|       WIRE LOCATION    |
|              12V|WHITE/ blue         |+  |ignition harness        |
|          STARTER|WHITE/ green        |+  |ignition harness        |
|   SECOND STARTER|WHITE/ red          |+  |ignition harness        |
|         IGNITION|BLACK/ red          |+  |ignition harness        |
|        ACCESSORY|WHITE/ black        |+  |ignition harness        |
|       POWER LOCK|add actuator       |   |in driver door          |
| PARKING LIGHTS +|RED / blue           |   |steering column         |
|     DOOR TRIGGER|PURPLE / white       |-  |driver side 'A' pillar  |
|  TRUNK/HATCH PIN|RED / white          |-  |trunk light             |
|FCTRY ALRM DISARM|blue               |+  |in driver door          |
|       TACHOMETER|WHITE/ stripe       |   |any fuel injector       |
|       BRAKE WIRE|WHITE/ green        |+  |brake pedal switch      |
|     HORN TRIGGER|GREEN/ orange       |+  |at horn                 |
|  LF WINDOW UP/DN|RED / wht - RED / blk  |A  |driver window switch    |
|  RF WINDOW UP/DN|blue - blu/red     |A  |driver window motor     |
Nissan Gt Skyline info -- posted image. the12volt • Support the12volt.com
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
