2003 toyota camry alarm/remote start info
murraymurray
Member - Posts: 25
Posted: December 02, 2003 at 7:12 PM / IP Logged
 Is there any information on installing remote starter in 2003 camery
murraywatchel
profuse007
Gold - Posts: 2,015
Posted: December 02, 2003 at 7:50 PM / IP Logged
you can find more install info by searching "03 or 02 camry"
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|WHITE/ red           |+ |ignition harness            |
|          STARTER|BLACK/ white        |+ |ignition harness            |
|   SECOND STARTER|BLACK / YELLOW        |+ |ignition harness            |
|        IGNITION|BLACK/ red           |+ |ignition harness            |
| SECOND IGNITION|BLACK / YELLOW        |+ |ignition harness            |
|   THIRD IGNITION|                    |   |                            |
|        ACCESSORY|blue               |+ |front of fuse box           |
| SECOND ACCESSORY|                    |   |                            |
|       POWER LOCK|blue / YELLOW        |- |driver kick panel           |
|     POWER UNLOCK|blue *1             |- |driver kick panel           |
|       LOCK MOTOR|blue/red            |   |driver kick panel           |
|     UNLOCK MOTOR|blue/black          |   |driver kick panel           |
|    DISARM DEFEAT|blue/black          |   |DKP, harness to rear        |
| PARKING LIGHTS +|green               |   |bottom of fuse box          |
| PARKING LIGHTS -|                    |   |                            |
|     DOOR TRIGGER|*2                  |- |*2                          |
| DOME SUPERVISION|comes on with unlock|   |                            |
| TRUNK/HATCH PIN|green               |- |DKP or light in trunk       |
|TRNK/HTCH RELEASE|WHITE/ blue          |5wi|driver kick panel           |
| FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
|       TACHOMETER|                    |   |                            |
|       BRAKE WIRE|GREEN / WHITE        |+ |bottom of fuse box          |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start. Use DEI module 555F or 555U to bypass. *1 Unlock requires a double pulse. *2 The driver door trigger is RED / green at lower left of the fuse box. The passenger door is RED / green at upper left of the fuse box. The rear door trigger is RED / white at the bottom of the fuse box. Use all three and diode isolate each.
Houston,TX
murraymurray
Member - Posts: 25
Posted: December 02, 2003 at 11:21 PM / IP Logged
Is the second starter black and yellow wire just a second ignition wire used to control power for the starter relay.
murraywatchel
murraymurray
Member - Posts: 25
Posted: December 04, 2003 at 7:01 PM / IP Logged
Is the black and yellow second ignition wire the same wire as the secound starter wire,and does it have to be powered to control the starter relay. I am just guessing this I never looked  at a wire diagram.
Thank You
Murray
murraywatchel
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
