1998 GMC 4-door Power Door locks
jeffl
Posted: December 10, 2003 at 11:30 AM / IP Logged
My door locks have been acting strange.  It has both remote entry and the usual power locks inside.
If I use the power locks then it will continue to lock/unlock/lock the doors rapidly, this may continue for a few minutes without touching them again. (sometimes I can hear the relay under the dash toggling very fast.) The same holds true if I use the key to open the hatchback window...toggling door locks.
The remote will sometimes work as long as this toggling relay has stopped (as described above).  I found 2 fuses in the fuses: a 5A labeled "mir/lcks" and a 15A labeled "pwr locks".  I removed the 5A and the remote entry works fine now, but obviously the power door lock button no longer function and the fast chaning relay has stopped altogether.  When I put the fuse back, it starts toggling all over again.
Could it be just a bad relay causing all this?  The relay can really start to switch fast and it is so strange because it may stop for a few seconds and then it just picks right back up and starts toggling all over again.  My only other thought a a loose connection or ground?
Any help is greatly appreciated.
draasch
Gold - Posts: 2,172
Posted: December 11, 2003 at 11:03 AM / IP Logged
yes it could be the relays....doule check the switches...did they get wet???
the contacts could be shorting out....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
jeffl
Posted: December 12, 2003 at 9:18 AM / IP Logged
Thanks for the reply.
It was raining on the day they quit, but it was garaged, so I guess I can count that one out.  :)       I pulled the controls out of the door, didn't see any loose connections. I don't have a diagram, so I'm not sure which wire is which, but I'm searching for a diagram now.
 Can you tell me where the relays are located?  Usually they are right beside the fuses, but they must be behind the dash somewhere?
draasch
Gold - Posts: 2,172
Posted: December 12, 2003 at 11:35 AM / IP Logged
Power Lock L BLUE DRIVER KICK #203
Power Unlock WHITE PANEL ** #202
** Without OEM Keyless Entry See Note #203. With OEM Keyless Entry See Note #202. #203 - See Reversal Rest At Ground Door Lock Diagram. #202 - See Positive Pulse Door Lock Diagram.
if you do not have a factory keyless, there are no relays.
Good Luck
David
Ace Security
813-376-9778
Tampa
jeffl
Posted: December 20, 2003 at 2:51 PM / IP Logged
After leaving the fuse out for a week and replacing it this morning, the locks are behaving normally.  I still tend to search out this problem.
I do have both keyless and door switches to lock the doors.
I appreciate your help.  It is nice weather today and I'm going back outside to try to find the problem.
jeffl
Posted: December 20, 2003 at 3:44 PM / IP Logged
Well, after doing more checking, now the rear hatch button does not work on the push-button located on the outside of the truck, the inside button on the dash works and so does the remote button.  I have a feeling there must be a loose connection or faulty switch in the push button.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
