Hummer H1, 01 & 02 alarm w/remote start
Irvin Cruz
Member - Posts: 11
Posted: December 12, 2003 at 8:11 PM / IP Logged
Please help!!!!! Have an H1 with diesel engine. Installing Clifford Matrix alarm w/remote start..Have everthing done, Door triggers, Door locks (5 wire), air horns honk w/alarm using relay w/flasher, wait to start wire diode isolated and per DEI wire 1090 diode is in correct direction, everything done per the installation guidelines (No t-taps, ground is perfect)...Have the tach wire at gauge cluster. When I went to program tach wire, CHECK ENGINE came on and Wait to start keeps flashing even after 2-3 minutes of waiting...Any help would be appreciated..
irvinjcruz@comcast.net
Platinum - Posts: 12,488
Posted: December 13, 2003 at 12:39 AM / IP Logged
Is the wait to start that you have a (-) or a (+)  on the Hummer ? Is it a (-) or a (+) input on the Clifford ?
