’96 Mercury Sable bypass module?
TheRapture
Copper - Posts: 208
Posted: December 16, 2003 at 5:14 PM / IP Logged
Hey all,
Looking at this:
http://www.northerntool.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=6970&catalogId=4006970&langId=-1&productid=1015746&cmemid=121603FS1705
only $50 for a regular remote start and keyless entry, good for the price?
This will be installed on a '96 Mercury Sable.
Was reviewing past posts and discovered that i may need a 555f universal by-pass modual. Do I need this? and what is it for?
Thanks for your help!
grimis1
Posted: December 16, 2003 at 5:25 PM / IP Logged
A 555f is a bypass module for vehicles equipped with PATS. You will need to factory programmed keys to program the unit,  whereas the 555u needs a third factory programmed key. The 555f may cost less however i have experienced that the 555f can be a little more picky about placement around the ignition, and can be a headache to fix sometimes.
MECP First Class Certified Installer
TheRapture
Copper - Posts: 208
Posted: December 16, 2003 at 5:35 PM / IP Logged
it does not have a stock keyless entry, so i do not need a by-pass unit?
and what is PATS?
Thanks again!
grimis1
Posted: December 16, 2003 at 5:40 PM / IP Logged
Passive Anti Theft System, It is an immobilizer system that will not allow the vehicle to run without a key in the ignition. The key has a transponder in it and there is a receiver around the ignition, the bypass tricks the system into thinking there is a key in the ignition. It isn't tied into the keyless entry so the car would have it reguadless
TheRapture
Copper - Posts: 208
Posted: December 16, 2003 at 7:52 PM / IP Logged
hmm, well how do i know if it has it or not?   there is'nt a Chip in the key that i have... or would it be in the "handle" part of the key? because the actuall metal key piece is just regular.
sorry for the ignorent questions :)
Thanks!
wiretapper
Copper - Posts: 166
Posted: December 16, 2003 at 8:08 PM / IP Logged
If the key has a THIN coating around it there's no PATS.
If it has a thick coating (like 1/4 inch)  with what looks like a rectangular  sort of door at the top of the key where the ring goes through, you need a 555F. Hope that helps.
brocclli13
Member - Posts: 6
Posted: December 17, 2003 at 1:16 AM / IP Logged
The alarm notes i have it says you need a 555f
TheRapture
Copper - Posts: 208
Posted: December 17, 2003 at 11:34 AM / IP Logged
alright, thanks guys, from the size of the Oval door at the top of the key... and you all saying to in your notes that it does need it... i'll go grab one.
Is this one from JCWhitney UNIVERSAL BYPASS MODULE from Bulldog (same brand as starter) ok for $20?
http://www.jcwhitney.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10101&storeId=10101&langId=-1&productid=190842&mediaCode=ZX&appId=506507
Or is there a website that is the 555f cheaper?
Thanks again for all your help!!
Geeque
Silver - Posts: 310
Posted: December 17, 2003 at 12:15 PM / IP Logged
Best way to tell is if you have a anti theft light that blinks when locked or ignition is turned off.
Gary Kline
MECP Master Technician
wiretapper
Copper - Posts: 166
Posted: December 17, 2003 at 12:31 PM / IP Logged
Godd point! I forgot that one.  If there's a blinking  "THEFT" on the cluster, you have it.  If not, you don't.
Check eBay for the bypass they're always on there. Most of the time less than $20.
