2002 Nissan Sentra Remote Start
Welcome Guest :)
elliotth123
Member -
Posted: December 30, 2003 at 11:07 AM / IP Logged
I am looking for info on installing a remote start into a 4 door nissan sentra GXE. I need wiring info and possibly a DIY if possible, any help would be great!
boomer_106
Silver -
Posted: December 31, 2003 at 1:36 AM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | BLACK/ WHITE & BLACK / YELLOW | IGNITION SWITCH HARNESS *, ** |
Ignition #1: | | BLACK/ RED | IGNITION SWITCH HARNESS |
Ignition #2: | | WHITE | IGNITION SWITCH HARNESS |
Ignition #3: | | N/A | |
Accessory: | | WHITE/ BLUE | IGNITION SWITCH HARNESS |
Brake Light: | | RED / GREEN | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | BLUE/ORANGE | INSTRUMENT CLUSTER |
Parking Lights: | | WHITE/ RED OR RED / BLUE (+) | DRIVER'S KICK PANEL OR AT HEADLIGHT SWITCH |
Headlights: | | RED / YELLOW & PURPLE (+) | AT HEADLIGHT SWITCH *** |
OEM Alarm Disarm: | | WHITE/ BLUE (-) | AT SECU **** |
OEM Alarm Arm: | | LT. GREEN/ RED | AT SECU **** |
Diesel Glow Plug: | | | |
Clutch Bypass Wire: | | | |
Notes: | | * This Vehicle Is Equipped With Two Start Wires. Both Must Be Powered In Order For Vehicle To Start When Engine Is Cold; See Note #235 - Nissan Starter Wires Diagram. ** Some Models May Have A Transponder Type Of Anti-Theft System. See Installation Note #144 - Bypassing Transponder Theft Systems. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | WHITE/ RED | IGNITION SWITCH HARNESS |
Starter Kill: | | BLACK/ WHITE & BLACK / YELLOW | IGNITION SWITCH HARNESS *, ** |
Ignition +12 Volts: | | BLACK/ RED | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | RED / WHITE (-) | DRIVER'S KICK PANEL OR AT SECU **** |
OEM Horn: | | WHITE/ GREEN (-) | STEERING COLUMN HARNESS |
Power Lock: | | GRAY (-) | AT MODULE RIGHT OF STEERING COLUMN***** |
Power Unlock: | | PRUPLE/RED (-) | AT MODULE RIGHT OF STEERING COLUMN |
Trunk Release: | | RED (-) | AT RELEASE SWITCH |
Alarm Input Wire: | | RED / WHITE (-) | DRIVER'S KICK PANEL OR AT SECU **** |
Notes: | | *** Use Both Wires. Isolate using relays. **** SECU Is Located To The Right Of The Steering Column. Use Red (-) & RED / White (-) On Vehicles Not Equipped With Power Door Locks. Diode Isolate With Bands Facing The Remote Start/Alarm Module. *****See Note #201 Negative Trigger Door Locks |
Hope it helps
elliotth123
Member -
Posted: December 31, 2003 at 6:02 AM / IP Logged
boomer_106
Silver -
Posted: December 31, 2003 at 11:51 AM / IP Logged
TranceTypeR
Member -
Posted: January 22, 2004 at 1:41 AM / IP Logged
need 2001 sentra wiring diagram please
boomer_106
Silver -
Posted: January 22, 2004 at 1:53 AM / IP Logged
| NISSAN SENTRA 2000-2001 |
| WIRE | COLORS | LOCATION |
| 12 VOLTS CONSTANT | WHT/RED | IGN HARNESS |
| IGNITION 1 | BLK/RED | IGN HARNESS |
| ACCESSORY /HEATER BLOWER 1 | WHT | IGN HARNESS |
| ACCESSORY /HEATER BLOWER 2 | WHT/BLU | IGNITION HARNESS |
| STARTER | BLK/WHT | IGN HARNESS |
| STARTER 2 | BLK/YEL | IGN HARNESS |
| PARKING LIGHTS | RED / BLU(+) | AT HEADLIGHT SWITCH |
| DOMELIGHT | RED / WHT | AT TIMING CONTROL MODULE |
| PWR DOOR LOCK | GRY | 16 PIN CONN IN DR KICK |
| PWR DOOR UNLOCK | PUR | TYPE B |
| TACH SENSOR | BLU/ORG | AT ENGINE CON MOD |
BRAKE | RED / GRN | AT SWITCH ABOVE BRAKE PEDAL |
HORN | GRN/YEL | STEER COLM |
FACTORY DISARM | WHT/BLU | LOCATED BEHIND DRV DASH |
NOTES: RED / WHT in the Driver's Kick Panel is used for vehicles without power doorlocks. If equipped with power doorlocks look for a RED wire for the Driver's doorpin and a RED / WHT for the Passenger's door at the Timing control module eight of the steering column.
Thursday, March 5, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
