adding trunl pin and sensor
Villa05
Member - Posts: 8
Posted: July 30, 2002 at 10:42 AM / IP Logged
i want to add another pin for the trunk of my car. do i just tap into the wire for the pin on the hood. and if i want to add another sensor, do i just tap into the wires of the existing sensors?
Moderator - Posts: 12,488
Posted: July 30, 2002 at 11:23 AM / IP Logged
Yes, just tap into the same wire for the hood pin switch. If you want to add another sensor make sure you diode isolaet the trigger wire so there is no feedback from the other sensors' trigger wire.
Villa05
Member - Posts: 8
Posted: July 30, 2002 at 11:27 AM / IP Logged
how do i diode isolate the wire? and which one is it?
Posted: July 30, 2002 at 11:36 AM / IP Logged
Usually it's the blue ( but make sure you check it ). It will be the wire that is ground until you trigger the device and it will pulse 12 volts. Use a 1 amp diode inline of this wire and have the band facing the device.
topinstaller
Member - Posts: 25
Posted: July 31, 2002 at 2:55 AM / IP Logged
Your sensor would actually rest at an open circuit and would pulse ground when triggered. The diodes band facing the device is correct that would allow ground to travel from the sensor to the alarms negative input wire. It is best to also diode isolate the hood and trunk triggers as well, especially if the trigger also turns on a hood or trunk light . This would prevent the trunk light from coming on when you simply just open your hoiod or vice versa. also prevents damage to the sensor. Most sensors have a 300mA or less negative ground output and trying to light a trunk bulb that may draw 1 or more Amps would eventually damage your sensor
I'm Don.I can answer all your security questions. I have 12 years in the industry.
Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
