Black Widow 3000 into a 2000 Ford F-150
jpw51
Posted: January 02, 2004 at 4:16 PM / IP Logged
I am looking for the wiring diagram of a 2000 F-150.  And if positive door input?  and the polarity.
Thanks for your help
jw
draasch
Gold - Posts: 2,172
Posted: January 02, 2004 at 11:04 PM / IP Logged
Make:   Ford
Model: Pickup - Fullsize
Year:    1999-00
This Database Was Last Updated On:    6/9/2003
Index #: 551
Alarm
Constant 12 volts L GRN/VIO, YELLOW, & ORG/YEL IGNITION SWITCH HARNESS
Ignition 12 volts D BLUE/L GREEN IGNITION SWITCH HARNESS
Starter RED / L BLUE IGNITION SWITCH HARNESS
Dome Light BLACK/ L BLUE (+) DRIVER OR PASSENGER KICK PANEL
Trunk Pin Switch N/A
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH *
Power Lock PINK / YELLOW ABOVE STEERING #201
Power Unlock PINK/L GREEN COLUMN ** #203
* BROWN (+) Wire Is Also Located In The Driver Kick Panel. ** Without OEM Keyless Entry See Note #203, With OEM Keyless Entry See Note #201. #203- See Reversal Rest At Ground Door Lock Diagram. #201- See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
