passlock 3
druid1200
Posted: January 10, 2004 at 2:10 PM / IP Logged
anyone know the passlock 3 wires,  I believe they are red, yellow, and black need someone to confirm please.  found resistance out of these wires and matched a resistor to the vehicle as close as possible, but I think the tolerance needs to be closer on the passlock 3 system.  I know there is a module that i can use through the data bus system but its saturday and there is none to be found.   anyone have any info.... thanks  ....Jones
druid
mindctrl
Copper - Posts: 114
Posted: January 10, 2004 at 2:47 PM / IP Logged
Use a module... The resistance tolerance on those systems is like less than 5% I believe.  Go on eBay or google and search for passlock transponders... Thats going to be your best bet.  As for the wire colors, what make, model and year of vehicle is this?
--mindctrl
sparkie
Platinum - Posts: 2,061
Posted: January 10, 2004 at 4:49 PM / IP Logged
If your vehicle which you forget to mention is really Passkey III, then it doesn't involve resistors. The key has a transponder inside it and you MUST use a module with either a spar key inside it or one which can be programmed so the vehicle sees it as a valid key. Most GM Passkey III keys have PK3 scribed into the metal part of the key.
sparky
Alpine Guy
Platinum - Posts: 2,478
Posted: January 10, 2004 at 6:36 PM / IP Logged
HUH? no it reads resistance, , you can actually bypass it with a relay and a resistor.   I completely forget how, my sheets on how to do it are at work.
druid1200
Posted: January 10, 2004 at 7:32 PM / IP Logged
I talked to one of my vendors and he said there is a module you can use through the databus system just like the door locks etc.. to bypass the passlock 3,  the wiring was similar to passlock 2 but different colors thats why I tried to use resistors.  I didnt mention the vehicle because passlock 3 should be the same in whatever vehicle it is. (04 avalanche) thanks though.....
druid
Bnluis
Silver - Posts: 578
pk 3 reads resistance???? I will like to see that diagram, As far as I know you will need a ke or a module to bypass without ot a key ( 555G ) some systems are fuel enable others are data enable you will have to see what kind of car.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
DanDan
Copper - Posts: 125
Posted: January 10, 2004 at 7:45 PM / IP Logged
The Avalanche should be Passkey 2 not 3. Pass 3 is a transponder and not resistive based. The module for the 2 is cheap and works good.
DanDan
Bnluis
Silver - Posts: 578
Posted: January 10, 2004 at 7:48 PM / IP Logged
Avalanche Passlock 2
Luis
Sound Waves
jrilla
Gold - Posts: 1,498
Posted: January 10, 2004 at 8:14 PM / IP Logged
Wierd I have a note here that says the 04 Avalanche can either be Passlock II or Passlock 3 (typo?). Maybe they are switching it over. Either that or they are coming out with a new one called Passlock III that no one has heard of. It was translated from french, so it may be a typo. Wierd though that it would sayit may have either.
One way to test to see if it is passlock II versus Passkey 3 (if the shaft of the key doesnt have PK3 on it) is to have a plain metal key cut and if it starts thge vehicle then it is passlock II. If not then it must be passkey 3.
J Rilla
Owner/Installer
jrilla
Gold - Posts: 1,498
Posted: January 10, 2004 at 8:19 PM / IP Logged
Sorry, I mis-read that note. It does have Passlock II.
Pay no attention to that bush, it's just a bush.
J Rilla
Owner/Installer
