subrau svx J registartion
msc19671
Posted: January 10, 2004 at 5:56 PM / IP Logged
does any one know how to connect up an alarm system to operate central locking on this vehicle.
martin
draasch
Gold - Posts: 2,172
Posted: January 10, 2004 at 6:48 PM / IP Logged
not sure what year you have but try this:
Make:   Subaru
Model: SVX
Year:    1992-93
This Database Was Last Updated On:    6/9/2003
Index #: 3876
Alarm
Constant 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Ignition 12 volts RED IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
Dome Light WHITE/ RED (-) AT COURTESY LIGHT
Trunk Pin Switch YELLOW/BLUE (-) TRUNK LIGHT OR PIN SWITCH
Parking Lamp RED (+) AT FUSE BOX
Power Lock BLUE/ORANGE DRIVER KICK PANEL OR DOOR LOCK #201
Power Unlock ORANGE TIMER BEHIND PASSENGER KICK PANEL
#201- See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
