1996 monte carlo Delta Vehicle Security
Imdabest2
Posted: January 15, 2004 at 4:21 PM / IP Logged
Bought this car used, Business is out of business, and now Parking lights will not come on, only time they come on is when starting car with remote, yet will shut off in 15, or shut off when driving. Would like to disconnect, yet wondering how. Any help woould be appreciated
Teken
Gold - Posts: 1,492
Posted: January 15, 2004 at 7:12 PM / IP Logged
Parking lights are: BROWN (+) which can be accessed at the headlight switch. Locate the RS / alarms wire and remove it.
Regards
EVIL Teken . . .
jrilla
Gold - Posts: 1,498
Posted: January 15, 2004 at 10:22 PM / IP Logged
If you are saying that the parking lights on the car do not work when turning them on from the switch, but only when the RS is on, then it sounds like you either have a blown fuse, or less likely is that the factory wire is broken or disconnected between the switch and the connection made by the installer.
So first check the fuse and if it is OK, then take a look under the dash for the parkinglight wire. I am not certain, but the parkinglight wire may be white coming from the Delta unit. The factory wire is brown as Evil mentioned.
J Rilla
Owner/Installer
Imdabest2
Posted: January 16, 2004 at 8:08 AM / IP Logged
You people are great. Thanks so much for your input.
Imdabest2
Posted: January 16, 2004 at 4:29 PM / IP Logged
Nothing still. replaced and checked all fuses pertaining to any sort of lights. Maybe if I explain how this happened, maybe I can than find out if even it is the remote. I started car with remote, drove it, and when I turned car off parking lights would not shut off. Warning chime going off even when keys out of car. Only way I got lights to shut off is by pulling battery cable. Is this a remote problem. Thanks in advance
jrilla
Gold - Posts: 1,498
Posted: January 16, 2004 at 5:00 PM / IP Logged
Did you check to see if the wire was broken? It does sound like there is something more serious wrong though.
J Rilla
Owner/Installer
Platinum - Posts: 12,488
Posted: January 16, 2004 at 5:34 PM / IP Logged
The problem might also be in the parking light relay on the board of the remote starter. If you can find the remote start unit and cut the parking light wire, this will narrow down the possibility that the remote starter is the problem.
Imdabest2
Posted: January 22, 2004 at 10:48 AM / IP Logged
Removed RS, checked Wire, must be a short somewhere. Got a ticket for no running lights, so hopefully autozone can diagnose. Thanks so much
