wiring for 2003 chevy tracker
Koolaid421
Member - Posts: 22
Posted: January 18, 2004 at 8:49 AM / IP Logged
lookin for wiring diagram for 2003 chevy tracker to use for remote start
thanks for the help
hell yea
bmf1000d
Silver - Posts: 345
Posted: January 18, 2004 at 11:07 AM / IP Logged
Sure no problem here ya go
CHEVROLET TRACKER 2002 - 03
WIRE COLORSLOCATION
12 VOLTS CONSTANTWHT/YEL to WHT/GRNIGNITION SWITCH HARNESS
IGNITION 1BLK/WHT to BLK/BLUIGNITION SWITCH HARNESS
IGNITION 2BLK/WHT to BLU/BLKIGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1YELLOW/BLACKIGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2BLUEIGNITION SWITCH HARNESS (not required for remote start)
STARTERBLK/YEL to BLK/REDIGNITION SWITCH HARNESS
PARKING LIGHTSRED / YEL (+)IN BLACK PLUG @ FUSEBOX
DOMELIGHTBLK/REDIN WHITE PLUG @ FUSEBOX
PWR DOOR LOCKPINK ( + )   DOOR LOCK RELAYS, @ RIGHT of BRAKE PEDAL
PWR DOOR UNLOCKPINK/GREEN ( + )also located at the keyless entry module, if equipped  (TYPE A)
TRUNK RELEASE
TACH SENSORBROWN  (AC)INSTRUMENT CLUSTER or ECM *SEE NOTES BELOW* 1
BRAKEGREEN / WHITE  ( + )@ BRAKE PEDAL SWITCH
HORNBLUE/BLACK to BLUE/GREEN (-)STEERING COLUMN
FACTORY DISARM
 NOTES:
*1 - The ECM (Engine Control Module) is located behind the glove box.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
