1997 Chrysler Sebring Convertible Tach
erinh
Copper - Posts: 91
Posted: January 19, 2004 at 12:04 AM / IP Logged
I just got done hookin up a RS and it usually does not crank on the first try. I'm guessing I need to hook up the tach wire. The site lists it as:
TachBLACK/ Gray Or Dark Blue/Green Coil Pack 2 Cylinder Setting
but I'm not sure where to look for either of those wires. Can anyone familiar with the car give me more detail about where to look? Or is there an alternate spot under the dash?
Thanks guys!
Erin H.
draasch
Gold - Posts: 2,172
Posted: January 19, 2004 at 12:07 AM / IP Logged
Tach Signal BLACK/ GRAY AT DISTRIBUTOR (6 CYLINDER) *
* 4 Cylinder Engine Tach Wire Is BLACK/ GRAY & D BLUE/GREEN At Coil Pack. Each Wire Is A 2 Cylinder Signal. ** D GREEN/ RED Powers Body Control Module & Transmission Control Module, BLACK/ ORANGE Powers Blower Motor & BLACK/ WHITE Powers Heat/Ac Controls.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
erinh
Copper - Posts: 91
Posted: January 19, 2004 at 12:19 AM / IP Logged
i found the distributor... i see a few wires plugging into it, but it is underneath a lot of stuff... there is only about an inch of room going to it, is there any alternate places?
erinh
Copper - Posts: 91
Posted: January 19, 2004 at 12:20 AM / IP Logged
by the way this is a 6 cylinder
draasch
Gold - Posts: 2,172
Posted: January 19, 2004 at 12:24 AM / IP Logged
thats all the info i have
Good Luck
David
Ace Security
813-376-9778
Tampa
Teamrf
Gold - Posts: 1,031
Posted: January 19, 2004 at 1:28 AM / IP Logged
What kind of alarm is it? Are you using Tach or Voltage sensing to remote start it? If you are having a hard time finding the tach under the hood you can always find the tach behind the instrument cluster.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
profuse007
Gold - Posts: 2,015
Posted: January 19, 2004 at 3:37 AM / IP Logged
i think if the info say that its on certain coil pack that mean that theres no distributor. modern cars have distributorless type which have its own coil right ontop of the spark plug. the coil might have 2-4 wires depend on ur car makes and models. unlike the older car which use a single coil to distribute to each cylinder. if you have 4 bangers, you have 4 coils not one and no distributor cap nor wires.
btw....2nd cylinder is the 2nd one from the timing belt (front side)
i hope am on the right track here.......
good luck!!!!
Houston,TX
