spark plug input signal ?
showtime
Member - Posts: 15
Posted: January 20, 2004 at 8:59 PM / IP Logged
where do i tap into the spark plug input signal. it's not the tach wire. on a 02 ford explorer.
daniel2002p
Silver - Posts: 524
Posted: January 20, 2004 at 9:17 PM / IP Logged
what do you mean, what are you trying to do???
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
showtime
Member - Posts: 15
Posted: January 20, 2004 at 9:22 PM / IP Logged
remote start
tblanning
Copper - Posts: 60
Posted: January 20, 2004 at 9:24 PM / IP Logged
you must mean tach signal
Tach  Signal:
BLUE/GREENAT COIL PACK
showtime
Member - Posts: 15
Posted: January 20, 2004 at 9:40 PM / IP Logged
the brain of the alarm has a tach wire and a spark plug input signal wire. im confused.???
tblanning
Copper - Posts: 60
Posted: January 20, 2004 at 9:53 PM / IP Logged
what system are you trying to instal
should only need tach wire
never seen or used one with spark plug input in the 16 yrs i have been installing remote starters
showtime
Member - Posts: 15
Posted: January 20, 2004 at 10:26 PM / IP Logged
the alarm is a trc (the right connections} xr-33
showtime
Member - Posts: 15
Posted: January 20, 2004 at 10:28 PM / IP Logged
corraudio
Member - Posts: 28
Posted: January 20, 2004 at 10:32 PM / IP Logged
showtime
Member - Posts: 15
Posted: January 20, 2004 at 10:56 PM / IP Logged
no programing just two wires listed as tach & spark plug input. maybe i can get by with out using it
Monday, January 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
