2001 F250 PSD Remote Start
russb
Member - Posts: 9
Posted: January 28, 2004 at 9:09 AM / IP Logged
I would like a wiring diagram for my F250 PSD Crew Cab 01'.
I am interested in installing an alarm with remote start.
Please advise on the best unit for this.
I would like the window roll up options.
84z
draasch
Gold - Posts: 2,172
Posted: January 28, 2004 at 10:45 AM / IP Logged
Make:   Ford
Model: Pickup - Super Duty
Year:    2001
This Database Was Last Updated On:    6/9/2003
Index #: 1541
Alarm
Constant 12 volts L GRN/PPL(2) & YEL(2) IGNITION SWITCH HARNESS
Ignition 12 volts RED / BLACK IGNITION SWITCH HARNESS
Starter RED / BLUE IGNITION SWITCH HARNESS
Dome Light BLACK/ BLUE (+) 40 PIN CONNECTOR ON FIREWALL * ***
Trunk Pin Switch N/A
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock PINK / YELLOW EITHER KICK ** #203
Power Unlock PINK/GREEN PANEL *** #201
* 40 Pin Connector Is Mounted On Firewall Behind The Driver Dash Top Of Two Other 40 Pin Connectors ** With OEM Keyless Entry See Note #201.W/out OEM Keyless Entry See Note #203 *** See Tech Notes For Alternate Locations and/or Wire Colors #201 - See Negative Pulse Door Lock Diagram. #203 - See Reversal Rest At Ground Door Lock Diagram.
Accessories
Window Up D\ WHT/BLK P\ WHT/YEL D\ GRY/ORG P\ YEL/BLK @ MAIN #211
Window Down F/ TAN/BLU F/ TAN/BLU R/ YEL/BLU R/ RED / BLK SWITCH
Ign Key Warn BLACK/ PINK (-) IGNITION SWITCH HARNESS
Trunk Release N/A
OEM Horn D BLUE (-) BROWN 6 PIN CONN. BEHIND DRIVER DASH
Headlights RED / YELLOW (+) AT HEADLIGHT SWITCH *
OEM Alarm Arm N/A
OEM Alarm Disarm GREEN/ VIOLET (-) BEHIND FUSE PANEL **
#211 - See Reversal Rest At Ground Power Window Diagram.
Remote Start
Tach Signal WHITE/ PINK 40 PIN CONNECTOR ON FIREWALL * #239
Ignition #2 GRAY / YELLOW IGNITION SWITCH HARNESS
Ignition #3 RED / BLACK IGNITION SWITCH HARNESS **
Accessory BLACK/ GREEN IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light RED / LT GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light BLACK/ PINK (+) AT SWITCH ON TRANSMISSION
Rear Window Defrost N/A
* Tach Wire Is Located In A 40 Pin Connector Mounted On The Firewall Behind Driver Dash Next To Two Other 40 Pin Connectors. ** There Are Two RED / BLACK Ignition Wires Present At Switch. One RED / BLACK Wire Is A Lighter Shade Of RED And Is The Main Ignition Circuit. The Second RED / BLACK Wire Is A Darker Shade Of RED And Is The Second Ignition. #239 See Immobilizer Bypass Diagram. See Tech Notes For Glow Plug Wire.
Glow Plug Wire Can Be Found As BLACK/ PINK (-) In Pin 37 Of A 40 Pin Connector On Firewall (Lower Of 3 Connectors.)
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
