help.. door lock unlock durango 2001
archimed
Posted: April 06, 2002 at 11:46 AM / IP Logged
i conenct my sécutity system on mydurango connect whit 2 relay and 2 resistor for lock and unlock but my systeme lock ok but no unlock..
the door
archimed@enter-net.com
Platinum - Posts: 12,488
Posted: April 06, 2002 at 12:16 PM / IP Logged
Here is a diagram to help you with the door locks. You may not have the resistance right on the unlock relay:
http://www.bulldogsecurity.com/wires/images/doddurangolocks01-02.htm
the12volt
Administrator - Posts: 3,959
Posted: April 06, 2002 at 12:18 PM / IP Logged
Hi archimed, on a 2001 Durango, you should have a 5 wire system if the vehicle was not equipped with a factory keyless entry. If it has a factory keyless entry, it will be a 3 wire positive system. Either way you do not need resistors to lock and unlock. The lock wire is ORANGE / Purple and the unlock wire is Pink/Purple.
On a 2002 Durango, it's a one wire (-) system, WHITE/ Green, 820 ohm to lock, 330 ohm to unlock.
the12volt
Smitty3572
Member - Posts: 16
Posted: February 04, 2003 at 6:00 PM / IP Logged
help.. door lock unlock durango 2001 -- posted image.Thanks for the posting. I am having same problem with my 2001 Durango. I cant locate the ORANGE / purple or the Pink /purple wires. Are they located at the central timer module? Or elsewhere?
Thanks Smitty
