Viper 690xv Remote
rckid
Member - Posts: 18
Posted: January 30, 2004 at 5:27 PM / IP Logged
I just got a 690xv off ebay and it is the one with the white remote. Is there a difference between the white and blue remotes? If there is, I can just get a new remote and it will work fine, right? I was going to get a second one anyway.
Thanks,
Clay G.
daniel2002p
Silver - Posts: 524
Posted: January 30, 2004 at 9:42 PM / IP Logged
no difference, blue one comes with belt clip, and can be used on 690xv
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Teamrf
Gold - Posts: 1,031
Posted: January 31, 2004 at 2:14 AM / IP Logged
Yea like Dan said the only diffrence is that one if the new version(Blue), and one is the older(White).
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
rudbwoy69camaro
Silver - Posts: 350
Posted: January 31, 2004 at 9:22 AM / IP Logged
478x-"old" lcd remote  479x-"newer" lcd remote.  I've heard of people having problems with the older remote.  If it does give you problems, go with the new one.  I keep  the remote separate from the keychain, so it doesn't get banged up.  Haven't had a problem yet.
rckid
Member - Posts: 18
Posted: January 31, 2004 at 9:25 AM / IP Logged
Ok, Thanks guys! Im going to install it today if it doesn't rain. But I can't find any spdt relays at radioshack! Ill try another place later.
Thanks,
Clay G.
