2000 dodge neon remote starter
peter884
Member - Posts: 8
Posted: February 06, 2004 at 10:39 AM / IP Logged
i have just installed a pro-start starter in mt neon everything works fine except when it starts my heater fan wont come on untill i insert the key and turn it on. if anyone has had this problem or knows what i did wrong please let me know thanks
peter
Trav3D1
Copper - Posts: 146
Posted: February 06, 2004 at 11:37 AM / IP Logged
Hello Willy,
It sounds like you did not hook up the "Accessory" wire from your alarm to the vehicle.  You should have a BLACK/ White accessory wire in your ignition harness.  Double check your connection to this wire.
Good Luck
Trav
peter884
Member - Posts: 8
Posted: February 06, 2004 at 1:22 PM / IP Logged
thanks trav your right it was a bad connection so i soldered the wires instead and it works great .
peter
