PATS system: need to program new key
ExactOh
Copper - Posts: 61
Posted: February 07, 2004 at 7:30 PM / IP Logged
Customer only has one ignition key because he lost one.  I never ask the customer to give up their spare key, but I do purchase a blank to cut and then program it following the procedure given in the vehicle owner's manual.  Only problem is, for this particular PATS system, the procedure in the manual requires two existing PATS keys to program additional keys.  Anyone aware of a procedure out there that only requires one key (besides taking it to the dealership)?
daniel2002p
Silver - Posts: 524
Posted: February 07, 2004 at 7:38 PM / IP Logged
none that i know of as far as i know it NEEDS two keys unless as said before you take it to the dealer.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
misterjimbo
Silver - Posts: 535
Posted: February 07, 2004 at 7:43 PM / IP Logged
you must have 2 keys. even if you have a wds or ngs machine you must have two keys.
ExactOh
Copper - Posts: 61
Posted: February 07, 2004 at 8:14 PM / IP Logged
That's what I thought, but I was just curious if there were any shortcuts out there.  Thanks.
