Alpine SEA-8081 Wiring Diagram
Twisted4runner
Member - Posts: 10
Posted: February 11, 2004 at 9:29 PM / IP Logged
I need a wiring diagram for this alarm and cantseem to find it on alpine's web site if someone could help that would be great.
bmf1000d
Silver - Posts: 345
Posted: February 11, 2004 at 10:43 PM / IP Logged
i dont have that model but i do have an lesser verison that i can give ya it may not have as many aux as yours but it will have the basics
Yellow wire: battery 12V with 20A fuse
Red wire: ignition 12v
Black wire: ground
BLACK/ White wire: negative door switch
BLACK / YELLOW: positive door switch
RED / black: negative trunk switch
RED / yellow: positive trunk switch
Orange: positive 12V out to starter cut relay
Blue wire: siren 12v output
Green: hoodlock 12V output
White: light flash negative output
WHITE/ brown: door lock output (may be unlock though)
WHITE/ yellow:door lock common (goes to 12v or ground depending on wiring)
WHITE/ green: door unlock output (may be lock though)
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
bmf1000d
Silver - Posts: 345
Posted: February 11, 2004 at 10:52 PM / IP Logged
better yet i found the page it was down here ya go
http://www.stylestandard.net/oswego/Rooms/RoomComponents/AssetView/AssetCount?qDocID=com.webridge.entity.Entity%5BOID%5B7E7896852F0FD511B0A700508BB8123D%5D%5D&Container=com.webridge.entity.Entity%5BOID%5B16F287D5FD327246959FD100027A7094%5D%5D
"Big" Mike
Double Take
Fremont, Ne
Platinum - Posts: 12,488
Posted: February 12, 2004 at 6:34 AM / IP Logged
Alpine SEA-8081 Wiring Diagram -- posted image.  Alpine SEA-8081 (uploaded by Velocity Motors on 5/3/2002)93 KB
 Alpine SEA-8081 wiring diagram ...( Alpine 8081 Alarm Wiring Diagram.pdf)
Twisted4runner
Member - Posts: 10
Posted: February 12, 2004 at 12:33 PM / IP Logged
Thanks you guys have been a huge help Ill let you know how it went
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
