domelight and door open problems
nickgf4i
Posted: February 12, 2004 at 4:17 PM / IP Logged
i have a 96 acura integra ls two door. i have a problem with the drivers side door trigger and dome light. for some reason the door is not turning on the domelight when opened and it is not registering open when the ignition is on. i have checked all of the fuses and there seems to be nothing wrong with the passengers side or the trunk, they both work fine. any help would be appreciated.
thank you
nick
bmf1000d
Silver - Posts: 345
Posted: February 12, 2004 at 4:54 PM / IP Logged
have you tried to clean the door pin
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Teamrf
Gold - Posts: 1,031
Posted: February 12, 2004 at 6:11 PM / IP Logged
Do you have that thing on your domelight that says "Door, On, Off?" If so make sure it's on "Door."
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
nickgf4i
Posted: February 12, 2004 at 10:24 PM / IP Logged
yes i have it on door, it works with the passenger door open. the passenger door will also set off the door open indicator on the gauge while the ignition is on and the drivers door will not. i tested the switch with a dmm and it is not recieving any power.
thank you
nick
jgold47
Copper - Posts: 69
Posted: February 13, 2004 at 9:58 AM / IP Logged
sounds like a bad switch...
might want to check out
www.team-integra.net
40000 integra owners.....cant go wrong there...and they/we know  tons about the car's electrical....
nickgf4i
Posted: February 13, 2004 at 9:23 PM / IP Logged
thanks. i will pull the switch out, test it and go from there.
thank you
nick
mecpcert_1
Copper - Posts: 83
Posted: February 15, 2004 at 3:17 AM / IP Logged
time for a new switch. it should only show 12v with the "door closed" or just push in the switch.
do it right the first time....less warranty work=more money!:)
S.I.Autosports
Copper - Posts: 98
Posted: February 15, 2004 at 4:30 AM / IP Logged
switch the two switches.  if the drivers side works and passengers doesnt you know the switch is bad.
fredisfound
Copper - Posts: 60
Posted: February 15, 2004 at 5:14 AM / IP Logged
switch is dead,,, replace it. I have the same prob with my Camry. Open back door and alarm doesnt work., switch is the prob.....cya.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
