Viper 550 ESP Install on A 96 Honda Accord
Canonm7
Posted: August 08, 2002 at 10:52 PM / IP Logged
Hey everyone,
This my first post on this forum.  My name is Stan.  Now I have installed my Viper 550 ESP on my car today.  Took about 10 hours or so.  I got everything to work except the remote start.  The doors lock and unlock, they lock when you start up the car & and they unlock when it's turned off.  Now the remote start attempts to start up but it goes and then conks out while trying.  Another problem that I found was that the accessories are always on.  When I remove the two fuses on the relay, that's for the remote start, they turn off.  So can anybody help me out?  Thanks in advance.
Sound Pressure
Silver - Posts: 711
Posted: August 08, 2002 at 11:47 PM / IP Logged
Double check your tach and remote connections, make sure that in your program mode that your alarm is detecting tach and not voltage. Hope this helps a little.  https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1996&make=Honda&model=Accord&ID=17959&type=Alarm
