How to disable passive arming
splcrazy
Posted: February 12, 2004 at 7:13 PM / IP Logged
I have a Toyota Landcruiser with an aftermarket alarm installed.  I can't get the brain out without a tremendous amount of work.  The alarm says it is a Falcon (no further info at this time), anyway it currently has passive arming set and I would like to disable this feature.  There is no valet switch so i'm sure it will be a combination of door open, ign. on etc..  Does anybody no the combo to deactivate this feature.  Thanks
profuse007
Gold - Posts: 2,015
Posted: February 12, 2004 at 7:37 PM / IP Logged
you have to have an installation manual for reprorgam the unit to active arming.
Houston,TX
Teamrf
Gold - Posts: 1,031
Posted: February 13, 2004 at 1:55 AM / IP Logged
I adivce you to find out some program instructions on that alarm if you want to turn that off...or talk to the retailer you got it from.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
