Clifford, RSX 3.5 Horn & remote?
JustDoIt2
Copper - Posts: 98
Posted: February 12, 2004 at 8:09 PM / IP Logged
HI, I have a  CLifford RSX 3.5 and I want to add the horn to the siren, but the alamarn does not have a horn Output, How could I do it to make it work.. thank you
and My other question, is DOes anybody know if I could use the Remote from the Viper 791xv to my alarm. the remotes looks pretty much the same....
thank you
sroth140
Silver - Posts: 513
Posted: February 12, 2004 at 10:32 PM / IP Logged
there is a horn honk wire, its just that its the same as the siren.  youd best use a relay even if your vehicle has a + trigger horn, just incase of current draw, and if its - youll need one anyway.  there is also a relay wiring diagram floating around out there that shows you how to set the horn up to sound different ways,  so you dont honk and chirp on arm and disarm.
Teamrf
Gold - Posts: 1,031
Posted: February 13, 2004 at 1:52 AM / IP Logged
Yes you can use the same remotes.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
JustDoIt2
Copper - Posts: 98
Posted: February 13, 2004 at 8:11 AM / IP Logged
ok, thank you guys
mecpcert_1
Copper - Posts: 83
Posted: February 15, 2004 at 4:19 AM / IP Logged
 go to the left of this page, at the bottom you'll see "Et Cetera", click "Site Search".
when the page comes up, go to the middle," Search the 12volt's install bay-Mobile Electronics Forum".
from the drop down menu, select "Author", then type "mecpcert_1"(that's me.Clifford, RSX 3.5  Horn & remote? -- posted image.) then click "Search".
scroll down to the bottom and click on "Viper horn alarm integra hookup",  look at my post, it will have what you need.
          the benefit to this is that the horn will only honk while the alarm is triggered. NOT on pre-warn or arm/disarm.
                          good luck and have fun!
do it right the first time....less warranty work=more money!:)
