Key Sense
Falcon 1
Copper - Posts: 130
Posted: February 13, 2004 at 10:03 PM / IP Logged
What is the key sense wire for and can someone please explain the connections. I am installing a prostart system in a 2004 Saturn L300 sedan. This is the first time I come across one with key sense. Thank-you.
Do it right the first time, only a doctor can bury his mistakes.
NowYaKnow
Gold - Posts: 1,217
Posted: February 13, 2004 at 11:16 PM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp?tid=25891&KW=key+sense
kgerry
Platinum - Posts: 3,455
Posted: February 14, 2004 at 2:21 PM / IP Logged
just hook up your status wire (ground out while running ) to key sense and everything will work fine
Falcon 1
Copper - Posts: 130
Posted: February 14, 2004 at 2:30 PM / IP Logged
Ok thanks kgerry.
