would it hurt anything
shredder130
Member - Posts: 41
Posted: February 14, 2004 at 12:53 AM / IP Logged
would it hurt to add another siren to my alarm with out adding a relay, i have an extra DEI 514T sitting in my room from my old car
thanks
italnpimp59
Silver - Posts: 427
Posted: February 14, 2004 at 12:58 AM / IP Logged
use a relay...if you dont, you stand a good chance at frying your alarm brain cause it doenst supply enough current to run two sirens.
JWorm
Platinum - Posts: 2,208
Posted: February 14, 2004 at 1:08 AM / IP Logged
Any DEI system will handle two sirens fine. They can usually handle up to three without a relay.
BangBang
Silver - Posts: 287
Posted: February 14, 2004 at 1:11 AM / IP Logged
yeah do wat jworm saids its what i would have to agree on. we tried doing it to a motor bike  and boy did it fry.
so find out more info on the siren you  have and plan on putting
serialthrlla
Copper - Posts: 57
Posted: February 14, 2004 at 1:12 AM / IP Logged
I ran two regular sirens and two piezo sirens off a clifford rs2 for like a year with no problems,    but a relay is not that hard to hook up so might as well
shredder130
Member - Posts: 41
Posted: February 14, 2004 at 1:35 AM / IP Logged
i have a bunch of extra 40/30 relays layin around, do you know where i could find the diagram to hook one up for this purpose.
 thanks
daniel2002p
Silver - Posts: 524
Posted: February 14, 2004 at 10:25 AM / IP Logged
use a realy, the brain only puts so much current out, and you really are not gainning a lot of volume, use a relay.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
FullForce
Copper - Posts: 103
Posted: February 14, 2004 at 9:18 PM / IP Logged
 thanks
pin 87 to 12V
pin 86 to ground
pin 85 to siren output wire
pin 30 to siren(s)
shredder130
Member - Posts: 41
Posted: February 14, 2004 at 9:51 PM / IP Logged
thanks
