Adding proximity sensor to existing alarm
SiDogg
Copper - Posts: 65
Posted: February 14, 2004 at 7:17 PM / IP Logged
I have the Clifford Arrow 5 and want to add a proximity sensor to my existing alarm. Can I just wire it in series with the shock sensor or does it need a separate input (does the Arrow 5 even support this as an input??)
Thanks!
bmf1000d
Silver - Posts: 345
Posted: February 14, 2004 at 9:55 PM / IP Logged
you have to check out dei website and see if the arrow 5 has an input for this you can do that here
http://www.directed.com/guides/igs.asp
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
SiDogg
Copper - Posts: 65
Posted: February 14, 2004 at 10:30 PM / IP Logged
Hmm, it doesn't really say. The wiring guide I found shows that it has a sensor input and a warning sensor input. Not two of each. I'm wondering if maybe it only has 1 sensor input? (I know it also has a sensor with the car's electrical system, because if you open the doors, trunk, or hood)
Can I piggyback (parallel wire) the proxy sensor in with the dual-zone shock sensor (which is using both inputs now). I doubt it would work if I wired in serial.
I hope they are both the same type of circuit (open until tripped).
SiDogg
Copper - Posts: 65
Posted: February 14, 2004 at 10:31 PM / IP Logged
If only one trips @ a time, then the alarm brain wouldn't be the wiser. If they both tripped, though, should I'd be worried about frying something... ???
